Looking for T5
Old Jun 30, 2008 | 07:32 PM
JN56's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 TPI
Transmission: 700R4 w/ shift kit
Axle/Gears: 9 Bolt BW 3.27
Looking for T5
Im looking for a whole setup so I can do a swap for my car. Its an '87. Im located in Massachusetts so closer is always better but will entertain any distance if it s agood deal! Thanks!
-Jesse
Old Jun 30, 2008 | 08:13 PM
Black Betty's Avatar
Car: '86z28 blacked out/'87 iroc yellow
Engine: '86-305 4bbl, '87-305 tpi
Transmission: '86-tremec tko600, '87-700r
Axle/Gears: '86-3.23, 87-? stock gear
Re: Looking for T5
I have a t-5. But you say a set-up. i am still using my old bell. r u switching from an auto.?
Old Jun 30, 2008 | 08:48 PM
JN56's Avatar
Engine: 5.7 350 TPI
Re: Looking for T5
yea, switching form auto. want to do a swap all at once so Im trying to get the housing, pedals etc. all at once if I can
Old Jul 3, 2008 | 10:29 AM
Re: Looking for T5
Don't blame u for that. But if u do end up w/everything but the trans send me a message. my old t-5 is in good shape.
Old Jul 4, 2008 | 09:38 AM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Re: Looking for T5
I bought the swap kit from hawks..not going to use it now. Still in the boxes...let me know
Old Jul 6, 2008 | 02:49 AM
Superjustin13's Avatar
Re: Looking for T5
I have One, but its not going to be cheap..
T5 (non Worldclass) (v8) Pulled it apart to rebuild it, Came to find out someones already rebuilt it, looks new inside, even had fresh Oil. so I ended up putting it Back Together With all new seals, *ASE master tech*
has bellhousing, I have the Pedals, and the complete slave/master cylinders, BUT the slave cylinder needs to be replaced, it was a Cheap autozone one, didnt hold up, I also have a MINT T5 Shifter plate 90-92 Style with New Boot,
I Also Have a Brand new Pro 5.0 Shifter, and shift ****, dont have crossmember but you can Use your Own.
For Everything, im Looking for 600+ Shipping.
the Shift **** and Shifter cost me over 250$
If you arent sure of what a Pro 5.0 Shifter is Look up Pro 5.0
Can also provide you with the stock Shifter and two shift *****.
it DOSENT have: crossmember, OR FLywheel!
