PS pump bracket
Old Jul 7, 2008 | 09:29 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
PS pump bracket
I have an 87 GTA 350 TPI.
I removed my ac and wanted to bolt the power steering pump to the block or head without bolting to the manifold.
Both non ac and ac 87's brackets bolt to the manifold, is there a truck or another vehicle with V8 that has brackets that bolts the PS pump seperatly?
Old Jul 12, 2008 | 04:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: PS pump bracket
yes the old carb style ones dont bolt to the intake
i think that will be the only option is to convert to carb style
i can help if you do
can take pics
you can keep the serpentine belt pulley by swapping it
good luck
Old Jul 13, 2008 | 09:16 PM
transamice's Avatar
Car: 87 GTA t-top
Re: PS pump bracket
Do you have a bracket kicking around?
My friend has an 83 Firebird carbbed, its the same as mine.
Send a pic if you can.
Old Jul 14, 2008 | 07:28 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: PS pump bracket
hey there, the large main pump mounrted bracket right ?
these use the front exhaust manifold bolt and separate smaller bracket
thanks
R
Squeaky8791
Feb 5, 2020 08:29 PM
evilstuie
Jan 9, 2020 08:29 PM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
