WANTED: 3.73 POSI rear end
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
looking for at least a 3.73 posi rear end to compliment the 6-speed swap i'm doing. the 3.08 rear i have just wont cut it. I'm already running 4th gen wheels and I have the correct adapters for them, so a 3rd or 4th gen rear will be just fine. does not matter if it is drum or disc, I already have the LS1 rear disc swap parts.... starting with a 4th gen rear would be the easiest, but will consider any as long as it is at least a 3.73 posi. a numerically higher ratio would be ok as well. preferebly around the Minnesota, Wisconsin, Iowa area so I could pick it up. Let me know what you have. thanks!
Re: WANTED: 3.73 POSI rear end
why dont you just install a new posi and gears i have a good looking posi that i bought off ebay that i never got to use my car got totaled it is for the 7.5 1987 GM rearend 26 spline i also have a good set of 3.73 gears to go with it 260$ plus shipping
Car: 1983 Z/28
i would prefer a 4th gen rear since i plan on doing the ls1 rear brakes. i found a 98 firebird rear with a 4.10 and a zexel lsd locally, i'm going to look at that within the next couple weeks.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
