dual radiator fans needed (both)
Old Oct 31, 2008 | 10:53 PM
mvtrumpetgeek13's Avatar
Car: 1992 Camaro
Engine: 5.7 L 350 V8
okay, so my radiator fans stopped working. THe one had been messed up for quite a while, now they both stopped working They are electric fans like the ones on the iroc and all 350 v8's
please tell me how much shipped to 91768, pomona ca or 92562 murrieta ca. I live at school in pomona, but i can go back home to murrieta to get the parts, or if perhaps you live close to either we can meet up and do it in person.
thank you guys
Old Nov 1, 2008 | 05:16 PM
Camfire's Avatar
Re: dual radiator fans needed (both)
I have a duel fan setup from a 90 bird TPI $90.00 shipped let me know thanks,Dave 716-445-0259
Old Nov 2, 2008 | 01:34 AM
Car: 1992 Camaro
is that for both with the brackets too?
Old Nov 2, 2008 | 02:27 AM
bluethunder28's Avatar
Check to see if the fuseable link is burned out. Sometimes one fan goes bad and the other fan will work until the link burns out.
I'm not that far from you and have another set of fans.
Old Nov 2, 2008 | 02:09 PM
Car: 1992 Camaro
yes, as a mater of fact there is a wire melted, but all the wires are wraped in that plastic wire thing to keep them neat, its hard to tell where it goes... its just a cluster of wire groups. what does the wire look like? the one that is burned out is coming off of the red terminal of the battery but it is a small yellow wire that connects into some sort of plastic link housing thing. Does that seem right?
how much for the fans?
Old Nov 2, 2008 | 06:43 PM
Yeah that sounds right. You"ll need to replace that link. All I did was put in a in-line fuse and replace the fan motor (about $34 from Autozone).
Are you at Cal Poly Pomona? I'm about 20 minutes away. PM if you want to meet and see what I did and double check the fans.
Old Nov 2, 2008 | 07:05 PM
Car: 1992 Camaro
pm sent
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
