[WI] WTB: Front Brake Swap Parts
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm going to be doing the LS1 front brake upgrade with either LS1 or C5 calipers. So, this is what I need... either LS1 calipers with all hardware and carrier or C5 calipers with previous stuff. I also need the adapter bracket that relocates the caliper. If you have some LS1 rotors in really good condition, I may buy those as well.
Let me know what you have
Mike
Mike
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
Re: WTB: Front Brake Swap Parts
i have the longer wheel studs that you are going to need. 5+shipping
Car: 1987 IROC-Z
Transmission: TH350
Engine: 400 sbc
sorry for not getting back to ya. i forgot to tell ya to pm me. i rarley find the threads that i post in agian so i usually tell people to pm me if interested. anyway they are new. i bought 2 sets when i did mine just in case but did not need them. Dorman part # 610-323 m12-1.5X54mm NIB.
Engine: 400 sbc
forgot to mention i also have the rear calipers for this upgrade if you are interested.
Car: 1987 IROC-Z
Transmission: TH350
I don't need the studs anymore. The person I'm buying the hubs from will be installing studs for me.
I don't need the rear calipers either. When it comes time to do the rear brakes, I'll just be swapping in the rear end from an 98-02 LS1 car because of the better brakes, stronger posi, perfect gear ratio (3.42) for my use, and direct bolt in install.
Thanks anyways,
Mike
Thanks anyways,
Mike
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
