Looking for a set of heads for a SBC 400
Old Mar 9, 2009 | 11:30 PM
gorski123's Avatar
Hey all,
I am in the process of building a SBC 400 for my 92 RS. It's a 4 bolt 511 casting. For the bottom end I have used an Eagle cast crank and a Federal Mogul rebuild kit:
http://store.summitracing.com/partde...0&autoview=sku.
The kit came with 12.5cc dish pistons that will give a compression of 9:1 with 76cc heads. I also have a Comp Cams 280H Magnum cam with 0.48 of lift and 280 degrees of duration.
I really do not want to use the crappy *** 882 heads I have, so I was hoping to find a good set of used heads for like 300-400 bucks. I would like to keep the compression below 10:1, so that means its prolly got to be 72cc or larger chamber. I really don't wanna use the vortecs b/c it will spike the compression and I don't think it will handle the lift of that cam. Also, I already have a standard performer RPM intake.
Let me know if you guys have anything you want to get rid of that would work for me.
Thanks!
Jason
Old Mar 10, 2009 | 09:07 PM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Re: Looking for a set of heads for a SBC 400
Lots of good heads on racing junk
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
CRFred
Feb 7, 2016 11:39 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
