[CT] 145 Gears Needed!
Old Mar 23, 2009 | 08:23 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
145 Gears Needed!
I just put in a 145 speedo and realized that the speedo is calibrated so i need drive and driven gears from a 700R4 if possible to have my speedo running correctly, and the other misc parts
Old Mar 23, 2009 | 08:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 145 Gears Needed!
The speedo will read correctly unless you've swapped in another rear with a different gear ratio. If you've done this swap, you'll need drive and/or driven gears which match the new rear.
JamesC
Old Mar 23, 2009 | 08:57 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Yep, the speedo isn't calibrated to anything. It is controlled by the drive/driven gear in the trans. which match the gears in the rearend.
IF your speedo was accurate before you swapped the cluster, then the new one should be accurate as long as nothing else was changed.
-jason
Old Mar 23, 2009 | 09:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Hm, i'll check about that, i'll swap back my 85 speedo and see if it works properly if not then it might be the gears.
IROCZ1989
Jan 24, 2016 03:55 PM
Firechicken86
Aug 12, 2015 10:07 PM
mizz0313
Aug 12, 2015 06:45 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
