90-92 proportioning valve disc/disc
Old May 25, 2009 | 05:19 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Looking for a proportioning valve for a camaro with the 1.5 mm 2nd verion came only in the 90-92 camaros ,need a disc to disc the part # for the 1990 is 10136840 and the 1991-92 is 10164112 can any one help
Old May 25, 2009 | 05:44 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 90-92 proportioning valve disc/disc
I have one that was removed from a 90 t/a a few years ago but the number on it is 18006814? $10 plus the ride if you can use it.
Old May 25, 2009 | 07:30 PM
Engine: 350 tpi
Transmission: auto
that # is the master cly but the porportioning valve was from a car with disc to disc correct its the silver box below the master cly correct
Old May 26, 2009 | 07:06 PM
Engine: 350 tpi
Transmission: auto
found a new thank s all
Old Jun 18, 2009 | 10:22 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
where did you find this new at?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Randomtask2
Sep 10, 2015 08:37 AM
