I am looking for a drive shaftfor a 1988 camaro that we put a TH400 trans in! Anything out there? Let me know!!
Kevin
Kevin
ted gerlach
close
- Join DateJun 2002
- LocationNew Jersey
- iTrader Positive Feedback100
- iTrader Feedback Score(28)
- Car89 formula convert looks like a 92
- Engineoriginal 350 tpi engine
- Transmissionauto
- Axle/Gears373 10 bolt with LS1 brakes
- Liked:0 Times in 0 Posts
is the drive shaft the same as a th350? if it is i have i one, its like 2 inches bigger than a stock 700r4 driveshaft,
Can you measure it from center to center for me?
Thank you for the reply!
the th350 shaft is a different length. If you still need one measure from center to center and call up Muscle motorsports and you will get one from them (after looking I think they are calling theirselves musclemotorparts now) anyway here is their link
http://musclemotorparts.com/index.html
they get used nascar parts and sell them. reasonably priced. if you are using the stock 10 bolt in back you will need a conversion U joint if you are using a 9" then you don't need to do anything other than install it.
spohn sells a bolt in driveshaft for the TH400 swap
here is the Ebay ad to musclemotorsports. just measure to make sure anyway they have these in alot of different lengths from 43" to 50". at least thats what it says. normally they are 4" driveshafts too but just call and ask them they probably have 3" too if that is what you want to go with.
ted gerlach
close
- Join DateJun 2002
- Transmissionauto
driveshaft mesures 44 3/4 inches
If you still need a drive shaft. I have one out of an 89 IROC Z28. 350 TPI to 700R.
$40. plus shipping.
$40. plus shipping.
