[OR] A few parts is all
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
A few parts is all
I'm in need of a few parts to make my car run a little better.
-Wonderbar (my Z28 doesn't have one)
-24mm rear sway bar (I prefer oversteer to understeer)
-Rear Calipers, rotors, disc proportioning valve, disc E-brake cable (My rear drums leak, why not upgrade)
-IROC/WS6 steering box (I have the standard ratio box, plus it leaks)
-Oil pan ( mine is bent at the drain plug hole and leaks)
-SLP LM1/2 cat back exhaust, TSP rumbler (Sounds better)
-Intake plenum cover that extends over the distributor
-ground control weight jacks
-lowering springs
-adjustable fuel pressure regulator
-LT4 hot cam
-airfoil
-Strut tower brace
-Sub frame connectors
-adjustable panhard bar
-700r4 to T-5 swap parts
Let's see what you guys have to offer.
-lowering springs
-LT4 hot cam
-airfoil
-Strut tower brace
Car: 87gta 88gta 88marovert
Re: A few parts is all
I have the
wonder bar 25.00
24mm rear sway bar 25.00
disc proportioning valve 16.00
iroc steering box 60.00
oil pan 10.00
intake plenum cover that extends over the distributor 16.00
+ shipping cost
Make me an offer cash talks
wonder bar 25.00
oil pan 10.00
+ shipping cost
-lowering springs
-LT4 hot cam
-airfoil
-Strut tower brace
-lowering springs
-LT4 hot cam
-airfoil
-Strut tower brace
Engine: LB9, LB9
what is the spring rate on those?
LT1Formula
20
Nov 14, 2015 12:02 AM
