MiniRam, Dart Pro 1 Heads, Longtubes, 3600 Vig, Short Block For Sale
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
Im re posting this as the pending sale fell through.
I have several parts that I need to sell as I am going in a different direction with my car. Below is a list of everything that needs to go. Pictures are available if you are interested.
I would like to keep the items grouped together as follows but will consider selling items individually. With the exception of the short block, none of the items below have been used. That means ONLY the short block has been used. The transmission has been rebuilt.
The following two sets of items are bolted to the L98 short block listed below so you have a complete motor ready to go.
Mini Ram Intake, TPIS F Body fuel rail kit, 30lb Ford Fuel Injectors ($1100). This is the complete setup and includes 48mm TB, filler neck, etc. Individually these would cost you at least $1500 before tax and shipping.
Dart Pro 1 200cc Cylinder Heads (angle plug), Scorpion Roller Rockers, and Proform Chrome Valve Covers ($1200). The heads are assembled and ready to use. Individually these would cost you at least $1600 before tax and shipping.
Hawks Thirdgen Long Tube Headers with Y pipe ($900). This includes the Y pipe. There is a dimple in the #3 tube to provide clearance for the spark plug. These headers normally run $1049 before shipping.
700R4 Transmission with Shift Kit – Rebuilt with a Vig 9.5” 3600 RPM Torque Converter ($800). The Vig alone would run you $735 before tax and shipping.
L98 Factory Roller Short Block ~ 15k miles; comes with the following items ($400):
*CC306 Hybrid Cam (230/245 .544/547 w/ 1.6's 113LS)
*TWR 2490L Forged Pistons
*Reconditioned Stock Rods
*Reconditioned Stock Crank (turned 10/10)
*Melling Hi Vol/Hi Pres Oil Pump
*Canton Road Race Oil Pan. (F-Body Pan)
NOTE: A new Canton oil pan would run you $320 before tax and shipping, and a USED one generally fetches about $200.
If someone has the cash and wants everything listed above I will let it all go for $4000. This will include the accessory bracket, alternator, AC compressor, water pump, etc.
If possible I would prefer to sell to someone in the NC, SC, GA.
E
E
Car: 92 Z/28...many more !
Engine: LY6 / pro charger
Transmission: 4L70E 5000 stall
Axle/Gears: Moser 9" 3.89 gear
Re: MiniRam, Dart Pro 1 Heads, Longtubes, 3600 Vig, Short Block For Sale
how much for miniram and fuel rails
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
erummel, Looks like you have been a member of this site for some time now and should know that you should not post things for sale on this page since this is the page for items wanted and not items for sale.
Just an fyi.
Just an fyi.
LT1Formula
20
Nov 14, 2015 12:02 AM
