90 Trans Am 5.0 TPI
Old Sep 1, 2009 | 04:30 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
90 Trans Am 5.0 TPI
1. Has anyone followed my posts?
2. I noticed that someone put up a post for some injectors recently, I too need some injectors. 5.0 TPI. My only concern is that the injectors that I purchase operate properly. Any help or replies is appreshiated.
Old Sep 3, 2009 | 04:31 PM
Re: 90 Trans Am 5.0 TPI
Still in need of those injectors, egh???
What is the size (in pounds per hour) of the injectors that the 5.0 uses???
Old Sep 3, 2009 | 05:08 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
the injector size is 19lbs. if you check on the tgo sponser page there are a couple of places that has new ones or refurburished(cleaned) ones..hope this helps you out..
Old Sep 3, 2009 | 08:12 PM
I currently have a set of 30 lbs injectors from accel. I saw a set of low impedance injectors from 75-90 lbs, on the sponsor's page. Looking for 19 - 22 lbs injectors. Thanks
Old Sep 8, 2009 | 12:49 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
i have stock injectors off a 91 5.0 tpi. working fine when removed as far as i know. pm me an offer if you want them.
Old Sep 15, 2009 | 06:04 PM
Could you shoot me a price???
Old Nov 6, 2010 | 12:07 AM
Well I'm glad to say that I purchased my 19lbs Injectors from Summit Racing. I assumed they would resemble the yellow 30lbs Injectors I also have from Accel, but instead they came in a nice ploished aluminum. Very Happy! With both the apperance and performance of my new injectors. With the TPI, you can actually see the injectors, unlike most cars. The performance is spectacular, WOW! It idles/feels super smooth !!!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
Exxon Limited
Aug 9, 2015 08:13 PM
