[OH] stock 3rd gen exh manifolds
Old Nov 27, 2009 | 07:22 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
hey guys i need the stock 3rd gen manifolds for my v8 s10 project. anyone have any laying arround.
Old Nov 27, 2009 | 09:12 PM
jonarotz's Avatar
Car: 91 Z28
Re: stock 3rd gen exh manifolds
I have a set. They are in real good shape. They are off a 91 Z28 with a 305 TPI.
Old Nov 28, 2009 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just an FYI: There were only 2 different manifolds for the V8's throughout the years, but they were different depending on what motor and gearing package they came on. Here is the breakdown.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
The manifolds from the single 3" cat and the dual 2.25" cats are interchangeable. On the passenger side manifold, some will have the heat riser butterfly valve, some will have a spacer, and some will just have a donut gasket. You most likely have the wrong manifold for your application. If you have the larger manifolds, then it may be worth it to get the larger y-pipe for some more performance. TransamGTA350
And, of course, the carbed versions will have a heat stove.
JamesC
Old Nov 28, 2009 | 08:32 AM
jonarotz's Avatar
Car: 91 Z28
The ones I have are from an LB9 with a single cat.
Old Nov 28, 2009 | 10:40 AM
mmiglass's Avatar
Want a title? Post!
Car: 1984 trans am
Engine: 5.0 ho
Transmission: 5 speed
Axle/Gears: good
have a set on a 1984 trans am. $70 shipped.
1992rs/ss
16
Jan 28, 2016 09:58 PM
transaero
Aug 31, 2015 01:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
