WANTED; 24/32 ECM Header connector
Car: 85 vette
Engine: 383 stroker
Transmission: zf6 black tag
Axle/Gears: 4:11
Wanted to buy; 24/32 ECM Header connector ECM (speed density)
Like this; http://http://www.eecis.udel.edu/~da.../ecm_swap_730/
I want to make a conversion wire harness. I have an 85 vette with MAF. I want to make a new harness so I can run the 7730 ecu 90-92 Speed Density MAP system. The ecm will still be mounted inside the car, so that is why I am not using a 'vette weather pack unit.
In a perfect world, it would be great to find one that someone has already made (plug & play), or to find someone that would make one.
Thanks in advance.
Thanks in advance.
