[NJ] ecm needed
Old Jan 13, 2010 | 03:18 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
ecm needed
I am looking for a working ecm for my 305 carb....im hearing noise in the dash and the speedometer glitches everytime the noise comes on so it has to be the ecm and i need one
Old Jan 13, 2010 | 03:58 PM
dave mc's Avatar
Car: 87gta 88gta 88marovert
Re: ecm needed
All of the garb cars had a cable driven speedo. You might want to check that out first, I would have ether a used cable or an ecm let me know what you find out.
Ops sorry I just saw you have a berlinetta dose it have a digital dash or an analog?
Old Jan 13, 2010 | 06:34 PM
Axle/Gears: stock
Re: ecm needed
its digital lol
Old Jan 13, 2010 | 07:58 PM
dave mc's Avatar
Re: ecm needed
check with John in RI hears a link to his page
https://www.thirdgen.org/forums/member.php?u=884
Old Jan 14, 2010 | 01:25 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: ecm needed
Thanx Dave,.........
The issue with your speedo is not the ECM. The Ecm only controls emission related functions and doesn't interact with the speedo directly. If your speedo ( cluster ) is having a problem,.... then it is almost certainly in need of replacement or repair.
*BE SURE to get the correct replacement cluster. Using a V6 cluster will cause your Tachometer to read WAY off !
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
