Proportinal valves needed.
Old Apr 21, 2010 | 07:08 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I need to find a set of proportional valves for a #.42 rear with disc brake setup. Anyone out there have some?
Old Apr 21, 2010 | 08:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Proportinal valves needed.
There's only a single combination valve (which includes a proportioning valve) on our cars. Ratio makes no difference. Do you need it for 82-88 Delco-Moraine calipers or 89+ PBR's?
JamesC
Old Apr 21, 2010 | 09:42 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
he needs 89+ its a 97 lt1 z28 rear& brake setup
Old Apr 22, 2010 | 07:10 PM
Engine: 350 S/B
Your right igotta355z28. '97 LS1 Z28 rear going into an '88.
Old Apr 22, 2010 | 08:41 PM
JamesC's Avatar
Then you need the first-design 1LE combination valve. Ed Miller sells them new, IIRC. BTW, if you haven't seen the following info, you may find it useful (toward the bottom):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Night rider327
Sep 16, 2015 02:20 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
