305 crank
Old Jun 19, 2010 | 08:54 PM
mikeselky85's Avatar
305 crank
hello i have an 88 camaro 305 and i am in need of a crankshaft with the 1 peice rear main seal....i live in delaware and am looking for one thats usable
Old Jun 20, 2010 | 02:55 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: 305 crank
FYI, i believe 305 and 350's share the same crank.... the cylinder bore separates the two? could be wrong?
Old Jun 20, 2010 | 03:00 AM
Re: 305 crank
different balancing...but a 350 crank in the 305 and it will vibrate apart
Old Jun 20, 2010 | 03:14 AM
nate perron's Avatar
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
Re: 305 crank
they share the same crank and connecting rods as long as you get a one piece rms crank from an 87 to 91 motor you should be fine the only difference is in the harmonic balancer and flex plate if you can reuse the old ones that would be perfect.
Old Jun 20, 2010 | 09:41 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: 305 crank
Very true. It is easier to put a 305 crank in a 350, than to put a 350 crank in a 305. The 350 crank is heavier. Good luck on you search.
Old Jun 20, 2010 | 10:13 AM
Re: 305 crank
yup
Reborn756
Sep 4, 2015 03:42 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
