[OH] ohio engine!!
Old Aug 9, 2010 | 11:27 PM
dvdlovesbball's Avatar
Car: 1987 iroc-z
Engine: 5.0 305 carb
Axle/Gears: stock 10 bolt
ohio engine!!
hi i live in cleveland ohio im looking for a motor for an 87 camaro. i want a 350, 400, or a 454. if u have one let me know wat u got. im having a hard time finding one in ohio. looking for something that needs rebuilt
Old Aug 10, 2010 | 12:18 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: ohio engine!!
look in my pix on profile of stuff for sale I am about 3 hours south of you or so but I have a few different ones
New 355 short block $1000 new 350 lg long block $750 or a 350 lg from 4x4 that needs rebuilt(1984 motor) Its short block $175
Old Aug 15, 2010 | 09:01 PM
gtanut's Avatar
Re: ohio engine!!
i am in missouri and i have a .060 350 kb pistons .125 dome balanced aluminum water pump 6qt pan flywheel has about 50 miles on it reason for selling got a great deal on bbc have about $1000.00 in it will take 500.00 for it thanks Bill
Old Aug 15, 2010 | 09:09 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: ohio engine!!
Call Bobb Jacobs @ Jacobs Pro-Formance Engines in Columbus Oh. 614-449-5761
Old Aug 26, 2010 | 12:23 PM
IROC86350's Avatar
Car: 1986 IROC-Z
Engine: 383 TPI
Transmission: 700R4 2500 stall
Axle/Gears: 3.70 Moser 9in
Re: ohio engine!!
I have a Long block 350 1pc rear main. Roller Engine. that needs a rebuild minus the cam. 500.00 obo
Also have a fresh 1pc rear main short block 383 with eagle rotating assebly and SRP pistons. but it may be gone this weekend. 600.00 obo
Old Aug 26, 2010 | 12:49 PM
sharkbait's Avatar
Car: 1975 Novamaro
Engine: 1988 305 TPI
Re: ohio engine!!
I have a 350 in my garage that I was using in my daily driver until I yanked it out in April to throw a tpi motor in. I believe it is a 1979 Camaro motor, not sure how many miles. It ran fairly strong and pulled 20 inches of vacuum at idle. It was using up coolant so I just replaced the head gaskets and head bolts and then ended up buying the tpi motor immediately thereafter. $200 gets you the motor oil pan to intake, starter and distributor. I also several carbs and TH350 trans with torque converter. I have a cherry picker in my garage and live on the westside of Cleveland. You could take it home tonight. PM me if interested.
Old Sep 7, 2010 | 10:56 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Re: ohio engine!!
I've got a 400 short-block, (block, crank, rods, pistons, balancer, flexplate, still assembled) standard bore, 4-bolt main. Should be rebuilt. I'm in the cleveland area too (east side). Can possibly deliver, depending on your location. Send me a PM for pics/info.
-Dave
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
