wanted 9 bolt pbr caliper brackets and dust sheilds
Old Sep 27, 2010 | 12:19 PM
camaro8tysvn's Avatar
Car: 87 camaro
Engine: 355ci
Transmission: richmond 5 speed
i have a pbr set up from a 10 bolt and i need everything to convert it to a 9 bolt, may trade 10 bolt parts if someone wanted to swap the same parts
Old Sep 30, 2010 | 12:13 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: wanted 9 bolt pbr caliper brackets and dust sheilds
I have a complete 9 bolt posi rear with e cables. I bought this rear from ThirdGenRanch over a year ago and they said it was in good condition. When I got the rear I just put it aside till I had time to go through it and put it on my car. As I studied about the 9 bolt rear, I noticed that the cones were bottomed out. I decided to remove the carrier (series III, 3:27 gears) and machine the cones down. To my surprise, two spider gears were seized to the four pin cross shaft,two ends of the cross shaft were broken in half and been wallowing out the case halves. I GOT SCREWED BIG TIME on this deal. Bad spider assembly, damaged case halves, cones wore out, bad brake rotors, missing PBR brake parts. They stated it had about 90,000 miles on it....My A**!!! Anyway, I'm going to stay with the 10 bolt and I would be interested in converting my 10 to disc....PM me and will talk more if interested.
Old Sep 30, 2010 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
All you need is the 9-bolt backing plates for the conversion. They are available at the following site:
http://www.flynbye.com/
JamesC
Old Sep 30, 2010 | 07:21 AM
Car: 87 camaro
Engine: 355ci
what about the dust sheilds
Old Sep 30, 2010 | 07:29 AM
JamesC's Avatar
Unneeded. Some OE's were equipped with them, some weren't.
JamesC
Old Sep 30, 2010 | 12:34 PM
85 ZXX's Avatar
My setup does not have dust shields.
Old Sep 30, 2010 | 01:48 PM
Car: 87 camaro
Engine: 355ci
i would be interested in the brackets then, i would rather buy them then trade, what do you think
Old Oct 2, 2010 | 02:49 PM
85 ZXX's Avatar
Yesterday,I was able to find a replacement series III carrier with all the parts that I need to repair my 9 bolt so I'm going to hold on to what I have for now. I'll let you know if it doesn't work out. Its so hard to find replacement parts for the 9 bolt and they have a hefty price tag on them. JamesC is right, email Ed Miller, he has what you need.
Old Oct 2, 2010 | 03:19 PM
Car: 87 camaro
Engine: 355ci
ya i was just trying to save some money i have 2 spare 9 bolts but they both have iron calipers
Old Oct 3, 2010 | 01:10 AM
85 ZXX's Avatar
I understand, did those 2 spare 9 bolts with the iron calipers have 2:77 gears? Last year That Piece Of Sh** 9 bolt that I bought cost me $450.00. I had to buy new rotors, $90.00, (2) ebrake springs, rebuild kits, hard lines 100.00 and now a replacement carrier with gears $250.00. As you can see I've got $900.00 in this frigging 9 bolt and it ain't even painted yet....LOL. I should have saved and invested in a 9 inch instead.
Old Oct 3, 2010 | 02:51 PM
Car: 87 camaro
Engine: 355ci
theyre both low mile 3.27s i have 350 into the both of them, then that 10 bolt is a 373 posi
Old Oct 3, 2010 | 09:47 PM
85 ZXX's Avatar
I'll post some pic's soon of my damaged 9 bolt carrier. Right now I have a 28 spline 10 bolt 3.08 drum in my Z. The original 26 spline 10 bolt 3.23 drum has a few missing teeth on the pinion gear. I recently purchased a set of 3.42 gears to replace the original 3.23 gears. My goal was to have the stronger 9 bolt rear with PBR disc brakes. Eventually I will upgrade the front to dual piston PBR's.
Old Oct 4, 2010 | 06:50 AM
JamesC's Avatar
Here's the upgrade, front and rear, that you suggest--with a 10-bolt:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Oct 4, 2010 | 07:10 AM
85 ZXX's Avatar
Great information JamesC, Thanks!!!
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
