Full TPI SETUP WANTED, with serp belt system. will trade custom carb setup worth 600
Old Oct 4, 2010 | 09:57 PM
1RedCamaro's Avatar
Hello,
Im looking for a full tpi setup. I need the distributer, wiring harness, sensors and it should have no dents. I am also looking for the serpentine system. I am willing to trade my Custom carb setup for it, I spent over 600 on a holly street avenger carb, weiand single plane intake and mallery HEI distributer. I can also throw in a .292 comp cam but its in the car right now.
I will be switching over to the zz4 cam with tpi setup.
My setup has about 1000 miles on it but I miss the tpi and i am changing my cam. i have all reciepts from summit racing its a 590cfm street avenger carb.
Old Oct 20, 2010 | 04:18 PM
relic87239's Avatar
Car: 1988 Chevrolet Camaro
Engine: In the market
Axle/Gears: 2.77
Re: Full TPI SETUP WANTED, with serp belt system. will trade custom carb setup worth
I have the crankshaft pulley, ac, tensioner bracket, water pump, air pump, and a new gator belt, all you would need is the alternator. I also have the distributor. let me know. I also have a new starter 8mm plug wires, iridium plugs, used coil.
Old Nov 3, 2010 | 12:30 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I have a baseplate, runners, plenum, dist, coil.
Let me know if you want pics.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
86IROC112
Aug 17, 2015 02:00 PM
