[IN] Few Parts Needed
Few Parts Needed
82-92 (Good Shape is a MUST)
Factory Spindles (Non 1LE)
Aluminum Driveshaft
Serp. Brackets
Fibreglass Hood (Factory 83-84)
36mm Hollow Front Sway Bar
24mm Rear Sway Bar
Front Lower Control Arms (Factory)
High Flow Exhaust Manifolds (Matching Set)
Price with shipping to 46077
Aluminum Driveshaft
Serp. Brackets
24mm Rear Sway Bar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Few Parts Needed
If you want the aluminum bracket that holds the alternator and power steering pump on the drivers side of a V8, I have one in excellent shape although not shiny shipped priority for $50. Get me your email address if you want pics or other info. Henry
And may have AC compressor and Alt. braces as well if needed
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a pair of 91 spindles, aluminum drive shaft, complete serp set-up, 36mm hollow front sway bar, but witch lower control are are you looking for front or rear?
