NEED TPI HARNESS!
Subscribe
Feb 24, 2011 | 06:05 PM
Whats up guys im looking for a wiring harness for my motor....must be in good shape with no cut wires or missing connectors...car is a 87 iroc with a 305 tpi and a automatic transmission...and the cold start injector thanks...let me know a price shipped to 79930 thanks.
Reply 0
Feb 24, 2011 | 07:15 PM
Re: NEED TPI HARNESS!
I have an 87 GTA harness (TPI). Harness was removed and replaced with OBDII. The fuse block is not included, so it was cut. You say no cut wires, but how else are you expecting someone to remove a harness form a car. The fuse block doesn't have plugs like a cluster or sensor. If you want pics i have them.
Reply 0
Feb 24, 2011 | 07:46 PM
hmm i have read the harness can be taken out with out no cutting required
Reply 0
Feb 25, 2011 | 07:02 PM
Well if you are pulling a harness from a bone yard you could hack up the fuse block. The harness i have is cut at the fuse block. All harness's have splices to them and have crimped connectors and pins.
I am not trying to change your mind, don't get me wrong. I have pictures of my harness if you are intertest let me know.
Thanks.
Reply 0
Mar 19, 2011 | 04:55 AM
i have a harness that i got with an engine i bought its a 86 trans-am harness it was cut in some spots but he gave me the parts he cut everything is there it just needs to be spliced if u want it i can splice it for u and sell it to u
Reply 0
Mar 19, 2011 | 12:33 PM
There is absolutely no need to cut a engine harness to remove it from the car. The major junction points like the C100 connector on the fire wall is held in place with one small bolt in the center and the connector pulls off and the wiring to the ECM has one retaing clip on the inside of the passenger compartment that holds the main harness an the ECM has 2 connectors that pull off as well.
I have one from a 89 but it does not have provisions for the cold start injector.
Josh
Reply 0
Mar 19, 2011 | 01:16 PM
ur right there is not need but this guy didnt know how to take it off so he cut it in some spots but its all there
Reply 0
Subscribe
