smog delete pully
Old Feb 26, 2011 | 07:24 PM
JAKES1963's Avatar
Car: 1992 camaro z28
Engine: 305tpi
Transmission: 5speed
smog delete pully
need gmpart#10186167
Old Feb 27, 2011 | 12:43 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: smog delete pully
look on summit. new one is like 40 dollars. not too bad. do a search on there.
Old Feb 27, 2011 | 12:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Also available at most NAPA stores, and I assume that Advance/AZ/Oreilly can order as well.
Old May 13, 2011 | 04:47 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Are you guys sure? The only smog delete pulley I can find easily is the smooth-pullied one that needs a shorter belt. I can't find the 10186167 except at gm parts direct now and it's $70
Old May 13, 2011 | 06:57 PM
JAKES1963's Avatar
Engine: 305tpi
summit does have the smooth pulley its off center so it takes the same size belt but i didnt like the way it looked ,just gutted air pump
Old May 13, 2011 | 08:43 PM
Car: 2000 BMW M5
I have the Summit 10129569 pulley and it seemed when I mocked it up today like it would need a shorter belt. Other threads on this board support that finding...hmmm Unless me (and everyone else) is installing it backwards (possible). Which way did you have the pulley kicked out, towards the outside of the engine or towards the water pump?
Old May 15, 2011 | 06:18 PM
luvmy64's Avatar
Or, you could just do this:
https://www.thirdgen.org/serpentine
Old May 15, 2011 | 09:53 PM
Car: 2000 BMW M5
I think whoever did that write up actually put the delete pulley on backwards and that is where the misinformation about needing a shorter belt with the smooth pulley came from...Jakes1963 I think you are right. I have to go try installing the smooth delete pulley flipped from how this pic has it, which I think is incorrect
Old May 15, 2011 | 10:23 PM
luvmy64's Avatar
that pic shows how to route the longer belt, thus deleting the pulley from the system altogether. I did it on my last Camaro and it worked fine.
Old May 16, 2011 | 08:43 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
second that.... i did this years ago and works fine for me.. no need for a smog delete pulley.. you need a belt thats 1 inch longer....
Old Sep 5, 2011 | 06:50 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Does anyone have the P/N for the longer belt?
jaridjohn
Oct 5, 2015 07:01 AM
