heads for 5.7l
Old Mar 11, 2011 | 01:35 PM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
heads for 5.7l
i am purchasing a corvette 5.7l motor from a 1990 corvette and i need heads for it. I have 305 heads but i am not sure if the will work so i thought i would look here. Not looking for anything special. just something i can bolt on or machine myself. I would perfer they be center bolted valve cover style but anything will do. and this is a budjet build for me so i am not looking to spend a ton of money i would like to keep it undr 200 if possible. please let me know thanks
Old Mar 11, 2011 | 05:36 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: heads for 5.7l
I have a set of factory 083 heads. Can do 200 shipped for the pair.
Josh
Old Mar 11, 2011 | 09:22 PM
88Z350's Avatar
Car: 1988 Iroc Z28
Re: heads for 5.7l
if the vette motor you are buying has heads they should be aluminum and are excelent heads for porting and you will see great gains for little bucks
Old Mar 12, 2011 | 01:06 PM
herbz28's Avatar
Engine: 5.0 tpi
Transmission: 5spd
Re: heads for 5.7l
the motor has no heads the owner is keeping the heads for another build he is using. I found ou the heads i have on my current car are 14102187 head which are the swirl port 305 heads. I think shipping would be a little expensive from canada but thanks for the offer. hopefully i can find someone a little closer who would be as kind as you are iroc-z28
Old Apr 7, 2011 | 03:08 PM
MitchellTN's Avatar
Want a title? Post!
Car: 1991 Z28
Axle/Gears: 9 Bolt 3:73
Re: heads for 5.7l
I have a set of alum. heads off of a 86 vette. 200+ shipping
Old Apr 10, 2011 | 04:06 PM
tuneupman's Avatar
Re: heads for 5.7l
did you find heads? i have 2 sets one is stock 350 the other are world product castings
Old Apr 11, 2011 | 10:39 AM
herbz28's Avatar
Engine: 5.0 tpi
Transmission: 5spd
Re: heads for 5.7l
i found a set of 191s for right now but have kinda halted the project right now due to some unfortunate financial pop ups
84z96L31vortec
Aug 20, 2017 12:16 AM
BAMiller
Sep 14, 2015 06:38 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
