[MO] Steel Fuel Lines
Old Apr 14, 2011 | 03:56 PM
TheGr8erG00d's Avatar
Steel Fuel Lines
I'm looking for the steel fuel lines that run underneat the engine. I've got a 305 TPI. Mine are rusted pretty bad from the po who just had the car sitting outside the past four or five years. Any help would be appreciated.
Old Apr 14, 2011 | 04:33 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Steel Fuel Lines
You mean underneath the car? Or do you mean the short lines that run at the front of the engine?
Old Apr 14, 2011 | 05:05 PM
Front of the engine.
Old Apr 20, 2011 | 10:47 PM
Just realized I posted wrong. I meant the line that runs from the filter to the throttle body. Not sure what I was thinking when I posted last time.
Old Apr 23, 2011 | 10:57 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
If you have a tpi car, theyre are hardlines that run from the filter to the frame rail near the booster, then turns into a soft rubber line to make a nice turn, then turns back into a metal line that mates to the fuel rails underneath the throttle body.
I have the rubber lines and short metal lines, not the lines that run from filter to near brake booster. They are very clean and have new orings. Let me know if you want some pics.
Old Apr 24, 2011 | 03:08 PM
Got ahead and shoot me some pics. You can message them to me or use my email, sjackson87@msn.com
I'll take another look at the shop when I go in on Monday.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
