Needing 700R4 VSS
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Needing 700R4 VSS
Anyone have a new 40-45 tooth VSS for the 700R4 tranny for sale ?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Needing 700R4 VSS
Have you tried to find what you need here:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
JamesC
Engine: 5.7 ltr.
What else could it be ? My speedo, tripo, and cruise works intermediately. I replaced the VSS 4 out buffer, no difference, so the only other thing that I can think of is the VSS in the tranny. Open to any suggestions/recommendations...
Engine: gone
Transmission: gone
Axle/Gears: gone
basically you want the electronic speedometer off the back of the tailshaft housing? I have one. Im not sure of the gear size but I wanna say it is green.
Engine: 5.7 ltr.
Not quite sure if I'm following you...Are you suggesting other than the 2 conductor wire speed sensor that fits in the large round hole in the tailshaft housing, held in with a huge "C" clip ? Like maybe the plastic gears may be bad ? My sensor has the "D" shape shaft and stamped 40-45 in the side of it..Took the GTA out for a drive today and the speedo, tripo is not working at all now after several miles of driving. I get torque convertor lock up. I mean the tranny shifts fine...
Engine: gone
Transmission: gone
Axle/Gears: gone
The part I have came off the back of the tailshaft. Ill get a pic of it tomorrow and post it here for you. cool?
