Posi-traction disc brake rear axle near Madison, WI
Looking for a posi-traction rear axle with disc brakes near Madison, WI. Needs to have the '82-88 Delco Moraine rear disc setup and a ratio around 3.23. I would prefer the GM 10-bolt but will consider an Australian 9-bolt axle.
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: Posi-traction disc brake rear axle near Madison, WI
I have a housing with everything but the diff and gears. I'm up in northern WI but I head to madison quite a bit. Let me know if you are interested at all.
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
