Michigan V8 to T5 Bellhousing Mechanical Linkage
Car: 86 Z28
Engine: 305 tpi light mods
I am looking for a Bellhousing to go from my 305 in my camaro to a t5 transition i got from a friend. I have a mechanical linkage clutch system and pedals off a 82 camaro parts car i have that had a 4 speed in it and i would like to find a t5 bellhousing for a mechanical linkage clutch. If anyoen has one laying around email me at mspierling@my.madonna.edu
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Michigan V8 to T5 Bellhousing Mechanical Linkage
If you decide to go w/ a hydraulic setup, I have that type of bellhousing.
Aside from the difficulties in adapting the mechanicals to the frame and
the inefficient mechanical clutch system in general this is not a smart or
cost effective move at all.
I have an 82 bird that came with the 4 speed and mechanical clutch. What
a piece of crap. The original bell crank was made of good all American
steel. It lasted till 1996 before it was so worn out i had to replace it.
Needless to say ALL the replacements i have found are made of the worst
steel on the planet, Chinese steel. The first replacement bent the first
time i pressed the clutch pedal after install. Am on the second one and
though it hasn't bent, it is already worn out. These linkage parts are not
cheap and ALWAYS sloppy after a couple of months of use. The ball crank
needed on the frame causes the frame to flex and crack needing
reinforcement after years of use.
BEST SOLUTION IMHO
Get you a 5 speed hydraulic pedal/master cylinder setup and a hydraulic
throw out bearing rather then a slave cylinder setup. This is cheaper and
WAY more efficient. I usually see pedal setups for about $75 with and
without master cylinder. Master cylinders are cheap. Hydraulic throw out
bearings run about $100 to $175 depending on which tranny your using.
You should not need to replace the bellhousing if using a hydraulic bearing.
I have been researching this for some time now so i can do the swap
myself. Currently in the market for the 5 speed hydraulic pedal setup.
Bearings
http://www.howeracing.com/c-534-throw-out-bearings.aspx
BEST SOLUTION IMHO
Bearings
Car: 86 Z28
BEST SOLUTION IMHO
Bearings
BEST SOLUTION IMHO
Bearings
