Need random bolts asap
Old Oct 29, 2011 | 08:51 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys need some help..I'm putting my motor together and I lost since bolts the harmonic balancer bolt for a 305 tpi...and the 3 bolts that hold the crank pulley on tbe balancer.....trying to get them asap as that's what's left to complete my motor assembly thanks.
Old Nov 18, 2011 | 05:26 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Need random bolts asap
Is this still an issue?
Main har-bal bolt should be available at most parts houses
(O'reilly, NAPA, etc.)
The pulley bolts are probably a standard metric size, also available
at parts houses & good hardware stores. The shoulders may be
a bit different, but a flat + lock washer will get the job done
just as well. Or flat washer + LocTite.
Good luck.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jk_Under
Sep 8, 2015 08:13 AM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
