[NY] T-5 Mechanical Speedo Tail Section - No longer needed!
Old Dec 12, 2011 | 08:29 PM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Like the ad says. I've got a 1994 WC T-5 manual transmission with the electronic speedometer hookup but I'm putting it in a 1982 Camaro with a mechanical cable.
I need the tail section that lets me hook up a mechanical cable.
Thanks!
Old Dec 12, 2011 | 08:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T-5 Mechanical Speedo Tail Section
An FYI that may be helpful (or not): With thirdgen T-5's, you can simply swap the mechanical speedo sleeve into the tail shaft of one which originally was electronic.
JamesC
Old Dec 12, 2011 | 08:50 PM
OdieTurbo's Avatar
Engine: 3.4L V6
JamesC
Yes, it is helpful! I did a little research to confirm and you are quite right! So, I do not need the tail section.
Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
