L98 or TPI Exhaust Manifolds
Old Feb 3, 2012 | 12:27 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Looking for good set of L98 or TPI exhaust manifolds. The AIR won't be used in this application as I will plug them off. Shipped to 54501.
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
Old Feb 3, 2012 | 12:46 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: L98 or TPI Exhaust Manifolds
I just looked at a spare set that I have from my old '84 L69, and they look identical to the ones from my '90 GTA. They are yours if you want them, if interested I could throw up some pics...
Old Feb 3, 2012 | 04:36 PM
FASTASSBIRD's Avatar
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
I have a cherry set with cherry smog tubes if you need/want those. would like 75 for the pair. no strip threads on the exhaust flange studs came off a 75k mile original car
Old Feb 10, 2012 | 04:23 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I have a pair from an 87 gta..l98 if you still need them....
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
