Fuel Tank and Sending Unit needed
Old Apr 1, 2012 | 06:00 PM
Tim Fontana's Avatar
Car: 88 IROC Z
Transmission: 5 Speed
Axle/Gears: 3:08
Need a clean fuel tank and sending unit for an 84 Z28.
Thanks,
Tim
Old Apr 1, 2012 | 07:18 PM
J-(Chicago)'s Avatar
Car: 85 88
Engine: 455 Olds
Transmission: TH350
Re: Fuel Tank and Sending Unit needed
https://www.thirdgen.org/forums/memb...g-unit-80.html
Old Apr 4, 2012 | 09:00 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a tank from a 87 formula but no sending unit. 20$
Where are you located?
I'd rather not ship but would if I had to.
Old Apr 4, 2012 | 09:15 AM
Car: 85 88
Engine: 455 Olds
Transmission: TH350
His sigline shows, Michigan.
Old Apr 4, 2012 | 12:02 PM
TTOP350's Avatar
I didn't even look at his sig.... I always look at the avatar I'm a tard, thanx.
Old Apr 6, 2012 | 06:35 PM
Car: 88 IROC Z
Axle/Gears: 3:08
Picked up a nice tank and sending unit from a member here in Michigan. Thanks for the replies guys.
Tim
Old Apr 8, 2012 | 06:47 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Did u pick up the one on here with the carb sending unit?? If u do not need the carb unit I have one with a pump I'd trade ya
Old Apr 8, 2012 | 08:44 PM
Car: 88 IROC Z
Axle/Gears: 3:08
Yes, I picked up the carbed tank and sending unit. Will be using all of it since the engine I built will use a carb. When I opened up the original tank in the car I found it had a pump in there but the car is carburated. Did the factory use it as a pusher pump to the mechanical pump? Or was it a low pressure pump that fed the carb and did not use mechanical pump? The car didn't have an engine when I got it, so I'm not clear as to how it was set up.
Thanks,
Tim
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Irocohio
Aug 12, 2015 08:03 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
