[MD] High flow tpi
Old May 7, 2012 | 11:47 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
High flow tpi
I'm looking for a for a high flow tpi base and runners or Someone to port the base And plenum I have so I can just get some decent runners and a throttle body. I'm going with a 383 stroker and need a tpi to keep up
Old May 8, 2012 | 11:03 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: High flow tpi
I've got a very nice TPIS Big Mouth TPI Intake. Cleaned and unported with excellent mating surface condition. $300 plus shipping.
Old May 8, 2012 | 11:22 AM
Car: 89 iroc
Engine: 355tpi
Re: High flow tpi
Cam u use any runners with that or just tips runners
Old May 8, 2012 | 01:56 PM
wesilva's Avatar
Transmission: 200R4
Re: High flow tpi
Any runners will work but aftermarket runners would give much better flow. If you are strapped for cash, use the stockers until you can afford aftermarket high flow units. You can also port the stock plenum. That won't cost you anything but some grinding tools and time.
Old May 8, 2012 | 02:42 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: High flow tpi
I have a ported plenum sitting in my garage if you are interested.
Old May 8, 2012 | 07:25 PM
jonarotz's Avatar
Car: 91 Z28
Re: High flow tpi
PM sent
LT1Formula
20
Nov 14, 2015 12:02 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
