350 tpi 5speed esc and ecm!
Old Jun 6, 2012 | 09:41 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
im doing a 305 350 swap and i need these 2 items. let me know if you have one and we can work something out. (has to be out of a 350 tpi 5speed)
Old Jun 6, 2012 | 10:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 tpi 5speed esc and ecm!
if you have a tpi 305 you have the 1227165 ecm already. I can help you bye reprograming the memcal if that is of any help.
Old Jun 7, 2012 | 11:50 AM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
Right right I realized that after doing some more research. I need the esc regardless though right? It's 85.00 off napa so I'll probably just buy it new. As far as the prom goes, don't I need a 350 prom as a base even if I do tuning in the future? I read that a 305 prom can't be changed to work with a 350. You need the 350 prom
Old Jun 7, 2012 | 12:05 PM
Engine: Lb9
Transmission: M20
if it is maf the i/o buffer and netress are the same its just the programing. If you were dealing with tpi speed density the knock filter soldered on the memcal is a different frequency from 305 to 350 and will not retard the timing correctly if a knock occurs. you will still need a 5.7 esc. here is a good deal on a ac delco 216-47
http://www.ebay.com/itm/ACDelco-216-...ht_1933wt_1063
Old Jun 7, 2012 | 12:11 PM
Engine: Lb9
Transmission: M20
A knock sensor is ac delco 213-324 for a 5.7L and I believe its a 213-325 for the 5.0, if you are looking for a memcal The 89 has a lean cruise but also uses vats.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
