engine swap-327
Old Jul 28, 2012 | 09:02 PM
2004chevyman's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
engine swap-327
hey people i looking for a 327 engine ,running or that canbe rebuilt and a 350 turbo trans for a good price
Old Aug 28, 2012 | 10:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: engine swap-327
have a good complete bolt in and go 6" tail TH350 trans with stock converter from a v-8 chevy car for 150 in central IL if you can figure out a way to get it to you from here
or anyone else interested? in IL?
its 3" too short for the truck i want to put it in i need a 9" tail one, or a 700R4 or a regular 400 trans from a '70's or '80's 2wd truck thats around 31.5" long overall, with the D/S yoke length included
text me anytime 217 671 7792
Old Aug 28, 2012 | 11:03 PM
Guest
Guest
Posts: n/a
Re: engine swap-327
Any specific reason you chose a 327?
Old Aug 29, 2012 | 07:08 PM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: engine swap-327
because i have 69 double hump 327 with a 700r trans that came out of a state tropper 2010 camaro,that will bolt right up to the 327 taht i am haveing rebuilt
Old Sep 1, 2012 | 10:51 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: engine swap-327
Just a friendly FYI....that transmission you have is a 4L60E. It's going to need a computer to run it.
And just throwing it out there but have you ever considered a short stroke 350? It's a 400 block (4.125" bore) with a 327 large journal crank and 6.25" rods. I have a 400 two bolt block with a stock bore and splayed four bolt conversion mains. A virgin steel forged 327 Corvette crank and a new set of Eagle 6.25" rods. The block will need machining. You will need main bearing spacers or special thick main bearings. And pistons...which are off the shelf 400 SBC pistons for a 6" rod. Every piston manufacturer makes them.
Old Sep 1, 2012 | 10:55 AM
3rd Gen Guy's Avatar
From: Cambridge, Minnesota... EHHH LOL !! I'm actually a hillbilly from Memphis Tn !!
Car: '84 Camaro
Engine: rebuilt 305 with extras
Transmission: Nothin special !
Axle/Gears: 3.23, NOT ENUFF, LOL
Re: engine swap-327
I have an older 327 but live in Minnesota so shipping would be high I'm sure...
Can get you numbers off the block if you want em
Old Sep 5, 2012 | 05:00 PM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: engine swap-327
i made a mistake on the trans ,now it is a 700r off a state troppers camaro but its from a 1987 camaro
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
