Cold start injector delete kit and wheel spacers to fit C5/C6 rims
Car: '76 LT, '87 IROC
i have a 350 tpi and im looking for everything i need to delete the cold start and also the chip to make the other injectors work in its place.
also im looking for a full set of wheel spacers so that i can fit some C5/C6 rims on my camaro.
pm me with what you have
thanks everyone!
thanks everyone!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cold start injector delete kit and wheel spacers to fit C5/C6 rims
I will reprogram you stock memcal for $65, change it too broadcast code AUJM that of a (no ninth injector) 1989 tpi 350 automatic transmission, remove vats, disable the egr and air pump function and code 32. Remap the timing tables plus 2 degrees and return with a tracking number.
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
if still looking i have the spacers
