[NY] Wiring harness retainers
Old Dec 13, 2012 | 11:12 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm looking for at least a pair of the metal retainers that are bolted to the upper bellhousing bolts for the wiring harness to be secured. I'd actually prefer 3 of them, but 2 is acceptable. Ill have to see if I can find the only one I have.
Old Dec 17, 2012 | 10:36 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Wiring harness retainers
Also looking for battery cables.
CAMARO V6 BATTERY CABLES WITH BATTERY ON PASSENGER'S SIDE. Positive V8 cable MAY work. Must also be pre-90 as the positive starter solenoid terminal changed in diameter and the 90+ cables don't readily fit on the older solenoid without modification.
I have driver's side battery cables and want to mount the battery on the other side (in case I end up eventually replacing the tray again... Can't find driver's side trays ANYWHERE). And I have yet to find a pair in a yard around here that hasn't been butchered.
Old Dec 18, 2012 | 04:49 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
pm sent
Old Dec 18, 2012 | 07:51 PM
Engine: 2.7L V6
Axle/Gears: 4.41
PM replied to...
Bump... Battery cables? Or even part numbers on a new pair?
Old Dec 28, 2012 | 08:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bump! Got the harness retainers today, but may still be looking for a third (need to go out and look at the harness first).
Nobody has a V6 Camaro they're parting with the battery on the passenger's side?
How's about a catalytic converter hanger for a T-5, single cat? The one that bolts to the trans?
Old Jan 1, 2013 | 10:35 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Bump... Still looking for the battery cables, cat hanger...
How's about a decent set of silver Z28 emblems (no dash emblem, just GFX and rear)? That one should be easy.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
