[PA] CCV hose assembly
Old Jan 7, 2013 | 07:06 PM
conlinj's Avatar
CCV hose assembly
I'm looking for the complete setup for the 88-92 TPI. I need the valve cover grommet, elbow, and molded hose. I'd prefer not to have the early style (85-87) with the metal tube and rubber elbows.
Thanks,
-Jim
Old Apr 14, 2015 | 04:25 PM
Quinonez05's Avatar
Want a title? Post!
Re: CCV hose assembly
Anybody know where can i find that hose /air tube. Cant find it in auto parts around here.
Old Apr 14, 2015 | 07:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You can find the VC grommet in the "HELP" section of most Autozone stores.... That CC Vent hose is probably going to be tough to locate.
Old Apr 15, 2015 | 06:27 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I have the older style assembly if wanted.
Old Apr 15, 2015 | 06:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
unless u get lucky and find a NOS unit, you'll just need to use bulk rubber emission hose.
Old Apr 17, 2015 | 11:16 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Do you have a pic of what you need,I may have that from an 88 TA 350 TPI.
Old Apr 17, 2015 | 12:58 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Dis Hose??
Old Apr 17, 2015 | 01:27 PM
TTOP350's Avatar
Originally Posted by Bob88GTA
Dis Hose??
Looks nice, that hose was the one from 88-89? correct? then they made a valve cover change in 90?-92 and the hose became shorter.
I could use one of each style myself.
Old Apr 17, 2015 | 01:43 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Correct 88-89. I found it on fleabay. Don't know if gmpartsdirect has it or not.
Old Apr 17, 2015 | 03:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Nah,I don't have that,I have these and a lot of others,don't know what there for.I think the one on the bottom WAS what Bob is showing,it is cut
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
