[WA] Springs
Old Feb 26, 2013 | 02:54 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Springs
Anyone have a set of lowering springs they're looking to sell? I need to do the 4x4 delete..Thanks
Old Feb 27, 2013 | 09:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Springs
I've got a set of Rancho springs, advertized as a 1 1/2" drop. They were originally red but started rusting so I blasted and re-painted them awhile back. Never used them in the car I was building,...... I've got the poly mounting pads too. $80 + shipping for the set.
Post your ZIP code if your interested & need a shipping quote.
Old Feb 27, 2013 | 12:04 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Re: Springs
98023 is my zip.
I am unfamiliar with Rancho springs for these cars, the only Rancho I am familiar with is 4x4 stuff. Do you have any links to info about them? Thanks
Old Feb 28, 2013 | 09:46 AM
John in RI's Avatar
Re: Springs
Rancho quit making suspension parts for ThirdGens a long time ago so detailed specs will probably be hard to find. I happened to get this set of springs and a Rancho adjustable front sway bar from a car I parted awhile back. I planned to use the springs in an 83Z I rebuilt a couple seasons ago, but never did.
The package is a heavy one, 43 pounds.......
USPS priority Mail = $99
USPS Standard post = $49
Fed Ex Ground = $60
P.S. I did still find the poly spring perches too....
LMK !
Old May 14, 2013 | 05:58 PM
ultraz's Avatar
Car: 02 UltraZ, 85 Z28, 98 WS6, 86 Vette
Engine: LS1, SBC 383, LS6, LS2, LQ9
Transmission: T-56, TH400, 4L60E,
Axle/Gears: 3.42s, 3.73s, 4.10s
Re: Springs
i have slp rear springs... thats a .75 inch drop so it will level the car out
Old May 15, 2013 | 09:15 PM
freddy_2_Smooth's Avatar
Car: 87 formula
Engine: 350tpi
Axle/Gears: stock posi
Re: Springs
I have a set of sportlines with half coil cut out of fronts and a set of generic springs that will really slam your car.. neither are really stiff or bouncy.. sportlines 80 plus shipping and generics 50 plus shipping..
Old May 16, 2013 | 10:16 AM
ultraz's Avatar
Re: Springs
NM i sold my springs last night... you don't SLAM ****ing muscle cars.. you lower them.. you SLAM POS imports
Old May 23, 2013 | 10:55 PM
Thirdgencustom's Avatar
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Re: Springs
I have a set . . Call or text and i give you part number.there new 443-527-9573 Jason more parts at https://www.facebook.com/ThisWeekInCamaro
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
