[NY] wanted aluminum master cylinder for 82-83 4 wheel disc brakes
Old Mar 21, 2013 | 01:13 PM
82tarecaro's Avatar
I am looking for an aluminum master cylinder for an 82 Trans Am with 4 wheel disc brakes. It HAS to be aluminum, not cast iron. It must be from a 82-83 car with disc brakes as the later fittings were metric. I plan on rebuilding it, so as long as the casing is good I am interested. I would need the part number off of it to verify that it is correct.
Old Mar 21, 2013 | 01:30 PM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
Re: wanted aluminum master cylinder for 82-83 4 wheel disc brakes
i have a brake master cyl out of a 85 iroc z it has the booster and prop valve still attached the car had drum brakes i can look for numbers on it to see if you can use it
Old Mar 21, 2013 | 04:14 PM
82tarecaro's Avatar
85 has metric fittings. It needs to be 82-83.
Old Mar 21, 2013 | 05:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Any way to help Identify it ?
If I'm looking at a drum and a disk prop valve - how do I know which is which ?? If there's a part number on it - where is it ?? Aren't all early prop valves "round" compared to the later "squared" version ??
Old Mar 21, 2013 | 06:56 PM
82tarecaro's Avatar
Not sure John. I don't know about the prop valves, but I was hoping the master cylinder had a part number somewhere on it.
Old Mar 22, 2013 | 04:52 PM
82tarecaro's Avatar
I found an NOS MC on Ebay - I hope it is the right one.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
