NEED A FUEL RAIL ASAP!!!!!!!
Car: 87 IROC
Transmission: auto
This Is Really Getting Aggravating! Does Anybody Have A Decent Fuel Rail Laying Around?? One Without Bent Lines Or Dirt Inside? My 91 Has Been Sitting Over A Year And A Half Because Of This Stupid Issue! Was Gonna Do The 6An Fitting Thing, But After Talking to My Old boss At A Machine Shop, I Don't like The Fitting In The Regulator Block...Not Enough Metal To Work With. Willing To Pay Top Dollar If Somebody Has One Off A Running Car! Don't Care What Year, I'll Cap The Cold Start Injector.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: NEED A FUEL RAIL ASAP!!!!!!!
if you do change your mind and want your fuel rail repaired and converted to npt to an lmk I have done a few and can assist.
Car: 87 IROC
Transmission: auto
maybe...I'm Not Totally Opposed To Doing It, Just Would Rather Have A Good Rail. I Worked In A Machine Shop For A Few Years, And I Know My Old Boss Knows His Stuff. But On The Other Hand, I Guess Nobody Has Ever had A Problem, Right?
Engine: Lb9
Transmission: M20
The inlet you can tap with 3/4 npt and do a 3/4 to an6 fitting . But There is a trick to getting the restricter out. The return on the fpr does require some reworking
This is one that I made stainless cross overs for and its rear feed.
The second pic Is of a tpi regulator I made into a universal regulator
On this las picture It was the first fpr I ever did and want a little deep on the return fitting.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
TPI fuel rail,.... $65 + shipping. If your interested than post your ZIP code and I'll use it to get a shipping quote for Ya'.
Car: 87 IROC
Transmission: auto
Got One Coming! Nice Work On That Regulator! How Much You Charging For Those Tubes? While I Have It Apart I'd Put Those In
Engine: Lb9
Transmission: M20
Ill make you up a set and include all the o-rings for $20 shipped. They are made from .028 3/8 stainless with the Saginaw o-ring flaring.
