need a few parts
Old Jul 31, 2013 | 01:28 AM
scy135's Avatar
Car: 85 Camaro Z28
Engine: Chevy 350 Small Block TPI
Transmission: 5 Speed Manual
need a few parts
I need:
Engine wiring harness maf
Tpi fuel rail with injectors
Belt drive pulleys
Smog system
E brake handle
Front/ rear bumpers
Intake snorkel
Maf
I'm new to this so you can text me at 7605877975 thanks
scy135's Avatar
Car: 85 Camaro Z28
Re: need a few parts
Or email icobian187 @gmail.com
Old Aug 4, 2013 | 01:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Do you need these parts for your 85 ??
What is your ZIP code ??
Old Aug 4, 2013 | 02:14 PM
scy135's Avatar
Car: 85 Camaro Z28
Yes it's for my 85 I'm putting on tuned port injection on it
My zip is 92234
Old Aug 4, 2013 | 05:56 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
I got 24lb injectors that bosch threes with low miles
Old Aug 5, 2013 | 01:15 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I have 82-02 V8 Ford Racing SVO Fuel Injectors (19lbs/hr)
bought new from WS6project 2 years ago, have roughly 5,000 miles on them
and I'm pretty sure I still have the fuel rail. I'll have to check later
Old Aug 6, 2013 | 12:08 AM
scy135's Avatar
Car: 85 Camaro Z28
ohh nice but right now my main priority is to get a tpi maf engine harness so if anyone has one that wont charge an arm and a leg let me know plz
Old Aug 6, 2013 | 12:09 AM
scy135's Avatar
Car: 85 Camaro Z28
from an 88 preferably
Old Aug 6, 2013 | 09:28 AM
John in RI's Avatar
I've got the 85 TPI harness, and Engine harness. Ground wire needs to be spliced onto the ECM harness and the Engine harness is missing a ground & the temp sensor plug.
Remember; Using an 88 harness will mean you'll need to use all 88 brackets and accessories so all the plugs on the harness will plug into them properly. You would also have to custom wire some stuff because the 88 harness doesn't plug directly into the 85 C100 Firewall connector without modifications ( for wiper wiring for example ).
Old Aug 6, 2013 | 09:42 AM
scy135's Avatar
Car: 85 Camaro Z28
I don't have an 85 ecm I have an 88 ecm so I don't think the 85 harness will work with mine although I can probably see if there's an 85 at my junkyard they're only like $30
Old Aug 6, 2013 | 09:45 AM
scy135's Avatar
Car: 85 Camaro Z28
85 tpi and carb ecms are different right?
Old Aug 6, 2013 | 10:35 AM
John in RI's Avatar
Yup,
P.S. Make sure that the PROM CHIP inside the TPI ECM you use is correct & matches your engine. (305ci or 350ci.)
Old Aug 6, 2013 | 11:35 AM
'86 Sport Coupe's Avatar
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
About the bumpers, Do you need just the plastic covers or the crash bars too?
Old Aug 7, 2013 | 08:30 PM
Eddie1986z28's Avatar
Car: 1986 Iroc Z-28
Engine: 1972 350 4V
Transmission: 1983 T5
Axle/Gears: Stock 2.73
Originally Posted by scy135
I need:
Belt drive pulleys
Smog system
E brake handle
Front/ rear bumpers
Intake snorkel
Maf
ive got an e brake handle. think I can get it shipped to you for 15.
Old Aug 7, 2013 | 08:36 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
I got tpi fuel rail also got e brake handle and maybe a maf not sure if its in good condition though
Old Aug 7, 2013 | 09:46 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Which smog parts do u need?...do u ha e the v-belts or serpentine set up?...
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
