[IA] 3rd Gen BW 9-bolt with 3.45 gears
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
I'm trying to track one of these down to re-install in my 1989 Formula. A complete assembly with brakes would be nice but I'm open to whatever might be out there.
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
Re: 3rd Gen BW 9-bolt with 3.45 gears
i have one in a fs thread , but im in upstate ny . 52k on it , 3.27 gears .
Car: 89 Formula
Engine: Nada - v4.0
Thanks for the offer but really want to locate one with the 3.45 gear set.
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
can you tell me how to verify the gear ratio?
i have a new parts car 87 TA and i was told it has 3.45
it's a 9 bolt drum brake
located near milwaukee, wi
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
9 bolt rear end where disc brake only off the line. 10 bolt -rear cover had 10 bolts 9 bolt rear the rear cover has 9 Bolts. For the ratio mark the pinon and axle for 3.45 pinion turns 3.45 times to get axle to turn one time.
From gm ratios for 9 bolts are 2.77, 3.23 and 3.45 you could get 3.70 from parts but was never offered off the line.
2.77 used a special posi unit none of the other gears work with it because of the relation ship of ring gear flange to the pinion.
To have never seen a 9 bolt that was not a cone type posi. Smoking the tires going around a corner wore out the cones in a hurry. 9 bolts still in production in Australia as a M78 rear but parts are $$$ 9bolt.com about only place to get parts from.
Hope that helps everyone...
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Car: 89 Formula
Engine: Nada - v4.0
Still looking.....and going to try again today to hook up with you MY-92-RS
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
96BlownSSragtop: I've got one - but with you in Iowa,.... It's just not going to happen ! Good luck with your search !
Car: 89 Formula
Engine: Nada - v4.0
bump to the top.
Maybe I'll have to road trip!
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
3.45 9 bolt for sale - 87 IROC Z28 70k on the donor car. $400 Rhinelander, WI
Car: 87 Iroc vert, t-top
I'm heading to Colorado in March, and would be willing to bring one out from this direction if you need me to.
I have the name and number of a guy I deal with regularly that had a 9 bolt a few months ago, completely rebuilt, but I don't know the gear ratio.
I will find his number if you're still looking.
Car: 89 Formula
Engine: Nada - v4.0
give me a call I can have it out ready to go asap
hello .... Knock Knock ?????
Last edited by MY-92-RS; Mar 24, 2014 at 07:20 PM. Reason: what just happened ????
Car: 89 Formula
Engine: Nada - v4.0
Thank you MY-92-RS. Now I just need to figure out a time to hook up with you to get it picked up.
eightsixseven
Dec 16, 2024 01:50 PM
