[GA] Various Parts needed for TPI swap
I need a few small items preferable all from one seller who is parting out a car. I am doing a TPI swap into a Nova on a shoe string budget. Let me know what we can work out.
I need:
TPI throttle cable bracket and hardware
TPI throttle cable
Oil pressure switch (Not a sender but a pressure switch)
Knock sensor for a 350 from a speed density car
Fuel pump block off plate (from passenger side of engine block)
I need:
TPI throttle cable
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Various Parts needed for TPI swap
To get the correct cable we will need to know if your TPI is MAF or SD.....
Also a good idaad to post your ZIP to for shipping quotes.
