Need throttle cable for 86' TPI, 350 knock sensor, oil pressure switch
Old Oct 28, 2013 | 07:44 AM
quick57's Avatar
Need throttle cable for speed density TPI, 350 knock sensor, and oil pressure switch. Preferable all from the same seller. Cash in hand.
Old Oct 28, 2013 | 09:10 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Need throttle cable for 86' TPI, 350 knock sensor, oil pressure switch
I've got a stock TPI Cable, $15 + shipping.
IMO - your better off getting the sensors new...... they should be cheap enough and there are several different types of OPS's so be sure to specify what year and engine your car has when you order it.
Old Oct 29, 2013 | 12:52 PM
quick57's Avatar
I need a throttle cable from a speed density car.
9192camaro
16
Feb 3, 2019 12:21 AM
db057
Aug 22, 2015 08:17 PM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
