[IA] looking for t56 swap for 91 camaro 350
Old Feb 10, 2014 | 06:05 PM
tjvz28's Avatar
Car: 91 Camaro Z28
looking for t56 swap for my 91 Camaro. car has 700r4 with 350
looking for whole setup
Old Feb 28, 2014 | 10:51 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: looking for t56 swap for 91 camaro 350
I have a T56 out of a 95 Camaro. Have the trans, bell, clutch, pressure plate, flywheel, aftermarket shifter, hydraulics, and pedal assembly. I drove the car before pulling the trans. It shifted well.
Looking for $1500 plus shipping.
If you want pics just let me know.
Old Mar 13, 2014 | 12:36 AM
HotRodV6's Avatar
Car: 93 S10 RCSB
Engine: Corvette LT1
Transmission: 93 M29 T56
Axle/Gears: 8 3/4
I have a 93 M29 close ratio T56 removed from a trans am at 83K miles and was stuck in 3rd gear. Took it to Texas Drivetrain Performance and had it rebuilt to stage 2 specs, and and its now ready to handle 600 at the wheels with no problem. Comes with a B&M Ripper Shifter that is in like new condition and has the B&M Hammer t-handle on it, also comes with a stock LT1 clutch but no flywheel, Bellhousing, clutch fork and pivot, i do not have the slave cylinder spacer, but you can get a new one from the gear box for 12 bucks.
This trans does not have the skip shift solenoid, and has the same gear ratios as the 01-04 corvette ZO6, works great with some 3.73 rear gears. It has not been installed or ran since the rebuild. I was putting this in my 93 S10 with the LT1, but came across a super clean 97 S10 SS with a blown 4.3 that im swapping in my LT1 into and keeping the truck an automatic, its just to clean to cut it up for the T56.
Im asking 2800 shipped for everything.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
