[TX] Looking to switch back to tpi. Anyone have the 92 rs setup?
Old Mar 30, 2014 | 08:36 PM
custom-crazy's Avatar
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
I have a 92 rs motor swapped 350 edelbrock performer intake casting #2101 with edelbrock 1406 carb. Tired of carb thing. Rough idles cold starts and tuning I want to go back to tpi. Anyone have a tpi system with harness?
Attached Thumbnails Looking to switch back to tpi. Anyone have the 92 rs setup?-image.jpg
Old Apr 14, 2014 | 03:10 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Re: Looking to switch back to tpi. Anyone have the 92 rs setup?
i have a tpi system off an 87 trans am, missing runner bolts and will need a new FPR, in good shape, bought it to switch back to tpi and decided to do an LT swap instead. i also have an unmolested 87 tpi harness and computer, this is all MAF not SD so im not sure whether you want to switch to MAF or are looking for SD setup
Old Apr 16, 2014 | 10:43 AM
bronc3buster84's Avatar
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
I have an a complete intake, all bolts, lt1 style throttle body, modified fuel rails for external regulator, and the fuel pressure regulator
Old Apr 21, 2014 | 11:17 AM
Car: 92 rs
Engine: 5.7
Axle/Gears: stock
i bought the wire harness, upper plenum, fuel rail, and runners from an 86 so now i will need the ecm with prom, the lower intake, and the throttle body.. let me know if forgot anything
Old May 28, 2014 | 02:08 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I have an early style ported throttle body. Make me an offer.
89GTAOz
May 16, 2020 09:31 AM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 13, 2015 08:28 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
marcusaw
Aug 10, 2015 08:13 AM
