MY-92-RS
close
Like it says I need PBR 1le caliper mounting brackets for my Dana rear end I believe it is the same as a ten bolt .. I don't think nine bolt bracket will work
John in RI
close
- Join DateAug 1999
- LocationRI
- iTrader Positive Feedback100
- iTrader Feedback Score(170)
- Car1984 Camaro Berlinetta
- EngineLT1
- TransmissionT56 6-speed
- Axle/Gears4.11 LS1 Rear End
- Liked:469 Times in 363 Posts
I've got PBR backing plates from a 95 LT1,..... Will those work for your set-up ?
( I know they work with on a stock thirdgen rear by adding a spacer..... )
MY-92-RS
close
yes those 95 brackets just just work those are not the real thick one are they like one inch wide if they are the 1/4 inch wide plate ones yes the will work PM me a price and lets work something out .Originally Posted by John in RI
I've got PBR backing plates from a 95 LT1,..... Will those work for your set-up ? ( I know they work with on a stock thirdgen rear by adding a spacer..... )
