Looking for tpi parts
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
I am looking for a tpi intake manifold for a camaro or firebird from either 87-88 and maybe a corvette tpi fuel rail if anybody has one for a good price.
Re: Looking for tpi parts
Ill even take just the half of the fuel rail with the fuel lines on it so I can change to a corvette fuel rail and get my tpi conversion to work with where my fuel lines come in at.
Car: Anything that handles
Engine: 383
Axle/Gears: 3.25
dcd2236
I have a couple manifolds and other parts for TPI. I'll check on the fuel rails-I think I might have cut one to modify it. Will let you know later today.
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
dont know if it helps or not but i have a fuel rail from a camaro. its in good shape and does not have the 9th injector
unfortunately that wouldnt work. Im looking for the vette fuel rail since mine is an LG4 carb car and my fuel lines come up on the passenger side and the vette fuel rail goes straight out on that side.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I have a intake and a set of rails with the 9th injector, from a 88 TA 350.PM me if interested.
I'm interested in the intake. The fuel rail I'm gonna pass on. I'm looking for the corvette tpi fuel rail or the half with the fuel lines. You got pics and a possible price on the intake?
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
i have a TPI intake from a 87 with 92K miles, needs to be cleaned a bit
missing the dist cover and throttle position sensor the head of one of the screws is broken off
otherwise it is complete
upper and lower intake, runners, hard vacuum lines, water neck, throttle body, cable bracket, fuel rails, every bolt for the intake
do you need a tpi throttle cable?
Sanjay
Aug 12, 2015 03:41 PM
