WTB: Wiring Connection for Oil Sending Unit 88 Firebird
Hi! So, my oil pressure gage on my 88 Firebird is always at the max... My mechanic friend discovered that the wire is just not connected, it's missing some clip that helps hold it in place. It's currently being held by duct tape. So if you push on it, it reconnects, then the gage starts working again just fine. Until I drive it a few blocks and hit a bump and then the wire comes out again. So, I've determined I need this part:
http://www.nookandtranny.com/mm5/mer...ry_Code=PIGTPI
Wiring Connector, 88-92 TBI/TPI Camaro/Firebird, Oil Pressure Sensor/Switch
Quality replacement pigtail (connector) with approximately 6" of wiring. Our wiring products are manufactured using all OEM style connectors and TXL grade wiring, color coded like factory for easy install.
Specifically coded for the following:
89-92 TBI/TPI Camaro/Firebird, Oil Pressure Sender/Switch on side of the engine block (3-wire sender/switch)
However that company doesn't ship to Canada! I am in Vancouver, BC, Canada. Does anyone have this part that could ship it to me? Hopefully not too expensive?
Email me at ferretnado@gmail.com or reply here. Thanks!
Alison
Alison
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
When I get home I'll dig around in my harness stock and see what I have.
Sent from my iPhone using IB AutoGroup
Ghettobird52
Jul 5, 2024 11:18 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
